[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.le/r.le.setup/main.c |no clones | 0 monsters | 0 warnings
Thu Dec 14 12:40:27 EST 2006
Hello markus,
ANALYSIS
raster/r.le/r.le.setup/main.c functions
main (Begins at: 42 Ends at: 126)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      32 |       |      OK |
LOC:          |      85 |       |      OK |
metrics are OK
get_pwd (Begins at: 132 Ends at: 142)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-14 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
