[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.to.vect/util.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Dec 14 13:40:59 EST 2006
Hello markus,
ANALYSIS
raster/r.to.vect/util.c functions
move (Begins at: 20 Ends at: 38)
Complexity: | 6 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 19 | | OK |
metrics are OK
find_end (Begins at: 43 Ends at: 68)
Complexity: | 5 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 26 | | OK |
metrics are OK
at_end (Begins at: 73 Ends at: 80)
Complexity: | 3 | | OK |
LOC: | 8 | | OK |
metrics are OK
read_row (Begins at: 82 Ends at: 122)
Complexity: | 4 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 41 | | OK |
metrics are OK
blank_line (Begins at: 124 Ends at: 129)
Complexity: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
