[GRASS-QA] GRASS QA: markus | ./grass6/general/manage/lib/do_copy.c |no clones | 0 monsters | 0 warnings
Thu Dec 14 15:37:12 EST 2006
Hello markus,
ANALYSIS
general/manage/lib/do_copy.c functions
do_copy (Begins at: 23 Ends at: 109)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      25 |       |      OK |
LOC:          |      87 |       |      OK |
metrics are OK
recursive_copy (Begins at: 112 Ends at: 186)
Complexity:   |      16 |     * |         |
CalledNBR:    |      22 |       |      OK |
LOC:          |      75 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-14 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
