[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.proj/main.c |no clones | 1 monsters | 0 warnings
Fri Dec 15 03:48:10 EST 2006
Hello markus,
ANALYSIS
vector/v.proj/main.c functions
main (Begins at: 15 Ends at: 221)
Complexity:   |      23 |     * |         |
CalledNBR:    |     101 |   *** | MONSTER |
LOC:          |     207 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
