[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.thin/thin_lines.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Dec 15 04:28:18 EST 2006
Hello brad,
ANALYSIS
raster/r.thin/thin_lines.c functions
thin_lines (Begins at: 33 Ends at: 174)
Complexity: | 12 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 20 | | OK |
LOC: | 142 | * | |
metrics are OK
encode_neighbours (Begins at: 180 Ends at: 193)
Complexity: | 2 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 0 | | OK |
LOC: | 14 | | OK |
metrics are OK
print_bin (Begins at: 196 Ends at: 207)
Complexity: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 12 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
