[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.to.vect/lines_io.c |no clones | 0 monsters | 0 warnings
Fri Dec 15 04:37:13 EST 2006
Hello brad,
ANALYSIS
raster/r.to.vect/lines_io.c functions
write_line (Begins at: 47 Ends at: 90)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
write_ln (Begins at: 95 Ends at: 160)
Complexity:   |      13 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      66 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
