[GRASS-QA] GRASS QA: markus | ./grass6/imagery/i.ortho.photo/photo.elev/main.c |no clones | 0 monsters | 0 warnings
Fri Dec 15 05:35:16 EST 2006
Hello markus,
ANALYSIS
imagery/i.ortho.photo/photo.elev/main.c functions
main (Begins at: 13 Ends at: 94)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      39 |     * |         |
LOC:          |      82 |       |      OK |
metrics are OK
select_current_env (Begins at: 96 Ends at: 106)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
select_target_env (Begins at: 108 Ends at: 118)
LOC:          |      11 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
