[GRASS-QA] GRASS QA: markus |
./grass6/raster/r.le/r.le.setup/polytocell/bmf_to_cll.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Dec 15 05:35:17 EST 2006
Hello markus,
ANALYSIS
raster/r.le/r.le.setup/polytocell/bmf_to_cll.c functions
main (Begins at: 26 Ends at: 132)
Complexity: | 13 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 36 | * | |
LOC: | 107 | | OK |
metrics are OK
quit (Begins at: 136 Ends at: 140)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 5 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
