[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/is.c |no clones | 0 monsters | 0 warnings
Fri Dec 15 05:48:10 EST 2006
Hello brad,
ANALYSIS
lib/gis/is.c functions
test_path_file (Begins at: 6 Ends at: 20)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
G_is_gisbase (Begins at: 28 Ends at: 31)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
G_is_location (Begins at: 39 Ends at: 42)
LOC:          |       4 |       |      OK |
metrics are OK
G_is_mapset (Begins at: 50 Ends at: 53)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
