[GRASS-QA] GRASS QA: markus | ./grass6/raster3d/r3.mkdspf/r3_find.c |no clones | 0 monsters | 0 warnings
Fri Dec 15 05:48:12 EST 2006
Hello markus,
ANALYSIS
raster3d/r3.mkdspf/r3_find.c functions
g3_find_dsp_file (Begins at: 11 Ends at: 26)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
check_get_any_dspname (Begins at: 30 Ends at: 57)
Complexity:   |       7 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
