[GRASS-QA] GRASS QA: markus | ./grass6/lib/db/dbmi_client/start.c
|no clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Dec 17 15:40:23 EST 2006
Hello markus,
ANALYSIS
lib/db/dbmi_client/start.c functions
db_start_driver (Begins at: 25 Ends at: 298)
Complexity: | 15 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 51 | * | |
LOC: | 274 | *** | MONSTER |
1 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-17 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
