[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/wind_format.c |2
clones ( parser.c wind_format.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Dec 18 03:26:05 EST 2006
Hello brad,
ANALYSIS
lib/gis/wind_format.c functions
G_format_northing (Begins at: 18 Ends at: 39)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 22 | | OK |
metrics are OK
G_format_easting (Begins at: 41 Ends at: 62)
LOC: | 22 | | OK |
metrics are OK
G_format_resolution (Begins at: 64 Ends at: 72)
LOC: | 9 | | OK |
metrics are OK
format_double (Begins at: 74 Ends at: 80)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
G_format_easting G_format_northing
In lib/gis/wind_format.c clones of G_format_easting are:
lib/gis/wind_format.c G_format_northing
In lib/gis/wind_format.c clones of G_format_northing are:
lib/gis/wind_format.c G_format_easting
Threshold GRASS6 key metrics values at 2006-12-18 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
