[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/unix_socks.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Dec 18 03:26:04 EST 2006
Hello brad,
ANALYSIS
lib/gis/unix_socks.c functions
_get_make_sock_path (Begins at: 61 Ends at: 107)
Complexity: | 7 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 47 | | OK |
metrics are OK
G_sock_get_fname (Begins at: 116 Ends at: 135)
Complexity: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 20 | | OK |
metrics are OK
G_sock_exists (Begins at: 144 Ends at: 163)
CalledNBR: | 2 | | OK |
LOC: | 20 | | OK |
metrics are OK
G_sock_bind (Begins at: 166 Ends at: 205)
Complexity: | 5 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 40 | | OK |
metrics are OK
G_sock_listen (Begins at: 214 Ends at: 226)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 13 | | OK |
metrics are OK
G_sock_accept (Begins at: 229 Ends at: 243)
LOC: | 15 | | OK |
metrics are OK
G_sock_connect (Begins at: 246 Ends at: 271)
Complexity: | 4 | | OK |
LOC: | 26 | | OK |
metrics are OK
G_sock_socketpair (Begins at: 276 Ends at: 284)
Complexity: | 2 | | OK |
ParamNBR: | 4 | | OK |
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-18 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
