[GRASS-QA] GRASS QA: paul | ./grass6/general/g.parser/main.c |no clones | 0 monsters | 0 warnings
Wed Dec 20 11:39:02 EST 2006
Hello paul,
ANALYSIS
general/g.parser/main.c functions
translate (Begins at: 33 Ends at: 41)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
parse_toplevel (Begins at: 43 Ends at: 72)
Complexity:   |       6 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
parse_module (Begins at: 74 Ends at: 104)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
parse_flag (Begins at: 106 Ends at: 147)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
parse_type (Begins at: 149 Ends at: 164)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
parse_boolean (Begins at: 166 Ends at: 178)
Complexity:   |       3 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
parse_option (Begins at: 180 Ends at: 263)
Complexity:   |      14 |       |      OK |
CalledNBR:    |      30 |       |      OK |
LOC:          |      84 |       |      OK |
metrics are OK
main (Begins at: 265 Ends at: 409)
Complexity:   |      16 |     * |         |
CalledNBR:    |      38 |     * |         |
LOC:          |     145 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-20 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
