[GRASS-QA] GRASS QA: markus |
./grass6/raster3d/r3.out.vtk/writeVTKData.c |1 clones (
main.c writeVTKData.c )| 0 monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Dec 21 09:38:40 EST 2006
Hello markus,
ANALYSIS
raster3d/r3.out.vtk/writeVTKData.c functions
get_raster_value_as_double (Begins at: 38 Ends at: 68)
Complexity: | 7 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 31 | | OK |
metrics are OK
get_g3d_raster_value_as_double (Begins at: 73 Ends at: 96)
Complexity: | 4 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 4 | | OK |
LOC: | 24 | | OK |
metrics are OK
write_vtk_points (Begins at: 101 Ends at: 240)
Complexity: | 5 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 46 | * | |
LOC: | 140 | * | |
metrics are OK
write_vtk_unstructured_grid_cells (Begins at: 245 Ends at: 307)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 63 | | OK |
metrics are OK
write_vtk_data (Begins at: 313 Ends at: 375)
Complexity: | 3 | | OK |
CalledNBR: | 15 | | OK |
LOC: | 63 | | OK |
metrics are OK
write_vtk_rgb_data (Begins at: 381 Ends at: 475)
Complexity: | 10 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 20 | | OK |
LOC: | 95 | | OK |
at least 1 values are close to an outlier please consider revising code
write_vtk_vector_data (Begins at: 481 Ends at: 557)
Complexity: | 8 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 77 | | OK |
Clone analysis:
This file has 1 potentially cloned functions:
In raster3d/r3.out.vtk/writeVTKData.c clones of get_raster_value_as_double are:
raster/r.to.rast3elev/main.c get_raster_value_as_double
raster/r.out.vtk/writeascii.c get_raster_value_as_double
Threshold GRASS6 key metrics values at 2006-12-21 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
