[GRASS-QA] GRASS QA: markus | ./grass6/raster3d/r3.in.ascii/main.c
|1 clones ( main.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Dec 21 09:49:38 EST 2006
Hello markus,
ANALYSIS
raster3d/r3.in.ascii/main.c functions
fatalError (Begins at: 50 Ends at: 59)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 10 | | OK |
metrics are OK
setParams (Begins at: 70 Ends at: 91)
Complexity: | 1 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 22 | | OK |
metrics are OK
getParams (Begins at: 96 Ends at: 107)
Complexity: | 3 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 12 | | OK |
metrics are OK
readHeaderString (Begins at: 112 Ends at: 124)
ParamNBR: | 3 | | OK |
LOC: | 13 | | OK |
metrics are OK
openAscii (Begins at: 129 Ends at: 157)
ParamNBR: | 2 | | OK |
CalledNBR: | 15 | | OK |
LOC: | 29 | | OK |
metrics are OK
asciiToG3d (Begins at: 164 Ends at: 220)
Complexity: | 8 | | OK |
CalledNBR: | 25 | | OK |
LOC: | 57 | | OK |
metrics are OK
main (Begins at: 224 Ends at: 286)
Complexity: | 6 | | OK |
CalledNBR: | 24 | | OK |
LOC: | 63 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
fatalError
In raster3d/r3.in.ascii/main.c clones of fatalError are:
lib/g3d/g3dclose.c G3d_closeOld
Threshold GRASS6 key metrics values at 2006-12-21 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
