[GRASS-QA] GRASS QA: markus | ./grass6/raster3d/r3.out.ascii/main.c |2 clones ( main.c main.c )| 0 monsters | 0 warnings
Thu Dec 21 09:49:38 EST 2006
Hello markus,
ANALYSIS
raster3d/r3.out.ascii/main.c functions
fatalError (Begins at: 53 Ends at: 64)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
setParams (Begins at: 70 Ends at: 110)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
getParams (Begins at: 116 Ends at: 121)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
writeHeaderString (Begins at: 128 Ends at: 135)
Complexity:   |       2 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
writeHeaderString2 (Begins at: 139 Ends at: 146)
LOC:          |       8 |       |      OK |
metrics are OK
openAscii (Begins at: 153 Ends at: 184)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
G3dToascii (Begins at: 191 Ends at: 240)
CalledNBR:    |       9 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
main (Begins at: 247 Ends at: 326)
Complexity:   |      13 |       |      OK |
CalledNBR:    |      28 |       |      OK |
LOC:          |      80 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  writeHeaderString2  writeHeaderString
In raster3d/r3.out.ascii/main.c clones of  writeHeaderString are:
	raster3d/r3.out.ascii/main.c  writeHeaderString2
In raster3d/r3.out.ascii/main.c clones of  writeHeaderString2 are:
Threshold GRASS6 key metrics values at 2006-12-21 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
