[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/area_poly2.c |no clones | 0 monsters | 0 warnings
Sat Dec 23 05:43:50 EST 2006
Hello brad,
ANALYSIS
lib/gis/area_poly2.c functions
G_planimetric_polygon_area (Begins at: 13 Ends at: 37)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-23 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
