[GRASS-QA] GRASS QA: brad | ./grass6/lib/segment/put.c |1 clones (
get.c put.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Dec 27 02:39:57 EST 2006
Hello brad,
ANALYSIS
lib/segment/put.c functions
segment_put (Begins at: 24 Ends at: 41)
Complexity: | 3 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 18 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
segment_put
In lib/segment/put.c clones of segment_put are:
lib/segment/get.c segment_get
Threshold GRASS6 key metrics values at 2006-12-27 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
