[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.to.points/main.c
|no clones | 1 monsters | 2 warnings
cvs at proxy.soccerlab.polymtl.ca
Sat Jul 1 16:40:28 EDT 2006
Hello markus,
ANALYSIS
vector/v.to.points/main.c functions
write_point (Begins at: 32 Ends at: 58)
Complexity: | 3 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 14 | | OK |
LOC: | 27 | | OK |
at least 1 values are close to an outlier please consider revising code
write_line (Begins at: 60 Ends at: 134)
Complexity: | 7 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 75 | | OK |
main (Begins at: 136 Ends at: 327)
Complexity: | 16 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 88 | *** | MONSTER |
LOC: | 192 | ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
