[GRASS-QA] GRASS QA: cho | ./grass6/vector/v.in.dxf/dxf_to_vect.c
|no clones | 0 monsters | 1 warnings
cvs at proxy.soccerlab.polymtl.ca
Sun Jul 2 20:43:16 EDT 2006
Hello cho,
ANALYSIS
vector/v.in.dxf/dxf_to_vect.c functions
dxf_to_vect (Begins at: 15 Ends at: 152)
Complexity: | 37 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 44 | * | |
LOC: | 138 | * | |
at least 1 values are close to an outlier please consider revising code
check_ext (Begins at: 154 Ends at: 170)
Complexity: | 7 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 17 | | OK |
metrics are OK
set_entity (Begins at: 172 Ends at: 179)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 8 | | OK |
metrics are OK
make_head (Begins at: 181 Ends at: 201)
Complexity: | 3 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 21 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-02 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
