[GRASS-QA] GRASS QA: cho | ./grass6/vector/v.in.dxf/main.c |no
clones | 0 monsters | 1 warnings
cvs at proxy.soccerlab.polymtl.ca
Mon Jul 3 19:06:23 EDT 2006
Hello cho,
ANALYSIS
vector/v.in.dxf/main.c functions
main (Begins at: 31 Ends at: 191)
Complexity: | 15 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 56 | ** | Warning |
LOC: | 161 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-03 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
