[GRASS-QA] GRASS QA: glynn | ./grass6/raster/simwe/simlib/input.c |no clones | 3 monsters | 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed Jul 5 04:31:04 EDT 2006
Hello glynn,
ANALYSIS
raster/simwe/simlib/input.c functions
input_data (Begins at: 24 Ends at: 336)
Complexity:   |      80 |   *** | MONSTER |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |     114 |   *** | MONSTER |
LOC:          |     313 |   *** | MONSTER |
3 metric are OUT OF RANGE!
grad_check (Begins at: 340 Ends at: 558)
Complexity:   |      25 |     * |         |
CalledNBR:    |      34 |     * |         |
LOC:          |     219 |    ** | Warning |
at least 1 values are close to an outlier please consider revising code
amax1 (Begins at: 561 Ends at: 572)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
amin1 (Begins at: 575 Ends at: 586)
LOC:          |      12 |       |      OK |
metrics are OK
min (Begins at: 589 Ends at: 602)
LOC:          |      14 |       |      OK |
metrics are OK
max (Begins at: 604 Ends at: 615)
LOC:          |      12 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-05 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
