[GRASS-QA] GRASS QA: hamish | ./grass6/imagery/i.vpoints/input.c |5
clones ( analyze.c ask.c input.c analyze.c analyze.c ask.c
input.c input.c )| 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed Jul 5 04:31:06 EDT 2006
Hello hamish,
ANALYSIS
imagery/i.vpoints/input.c functions
Input_pointer (Begins at: 19 Ends at: 22)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
Input_box (Begins at: 24 Ends at: 27)
ParamNBR: | 3 | | OK |
LOC: | 4 | | OK |
metrics are OK
Input_other (Begins at: 29 Ends at: 45)
Complexity: | 2 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 17 | | OK |
metrics are OK
mouse (Begins at: 47 Ends at: 103)
Complexity: | 12 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 57 | | OK |
metrics are OK
use_mouse_msg (Begins at: 106 Ends at: 111)
LOC: | 6 | | OK |
metrics are OK
draw_objects (Begins at: 113 Ends at: 177)
Complexity: | 8 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 65 | | OK |
metrics are OK
find (Begins at: 179 Ends at: 201)
Complexity: | 7 | | OK |
LOC: | 23 | | OK |
metrics are OK
select_option (Begins at: 203 Ends at: 215)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 13 | | OK |
metrics are OK
draw_option_boxes (Begins at: 217 Ends at: 236)
LOC: | 20 | | OK |
metrics are OK
visible (Begins at: 238 Ends at: 243)
LOC: | 6 | | OK |
metrics are OK
Menu_msg (Begins at: 245 Ends at: 265)
LOC: | 21 | | OK |
metrics are OK
Start_mouse_in_menu (Begins at: 267 Ends at: 274)
LOC: | 8 | | OK |
metrics are OK
Clone analysis:
This file has 5 potentially cloned functions:
Menu_msg draw_objects find select_option draw_option_boxes
In imagery/i.vpoints/input.c clones of select_option are:
imagery/i.points/input.c select_option
imagery/i.ortho.photo/photo.2target/input.c select_option
imagery/i.ortho.photo/photo.2image/input.c select_option
imagery/i.class/input.c select_option
In imagery/i.vpoints/input.c clones of Menu_msg are:
imagery/i.points/input.c Menu_msg
imagery/i.ortho.photo/photo.2target/input.c Menu_msg
imagery/i.ortho.photo/photo.2image/input.c Menu_msg
imagery/i.class/input.c Menu_msg
In imagery/i.vpoints/input.c clones of draw_option_boxes are:
imagery/i.points/input.c draw_option_boxes
imagery/i.ortho.photo/photo.2target/input.c draw_option_boxes
imagery/i.ortho.photo/photo.2image/input.c draw_option_boxes
imagery/i.class/input.c draw_option_boxes
In imagery/i.vpoints/input.c clones of find are:
imagery/i.points/input.c find
imagery/i.ortho.photo/photo.2target/input.c find
imagery/i.ortho.photo/photo.2image/input.c find
imagery/i.class/input.c find
In imagery/i.vpoints/input.c clones of draw_objects are:
imagery/i.points/input.c draw_objects
imagery/i.ortho.photo/photo.2target/input.c draw_objects
imagery/i.ortho.photo/photo.2image/input.c draw_objects
imagery/i.class/input.c draw_objects
Threshold GRASS6 key metrics values at 2006-07-05 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
