[GRASS-QA] GRASS QA: hamish | ./grass6/ps/ps.map/ps_colors.c |no
clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Fri Jul 7 06:16:17 EDT 2006
Hello hamish,
ANALYSIS
ps/ps.map/ps_colors.c functions
get_color_number (Begins at: 37 Ends at: 47)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 11 | | OK |
metrics are OK
get_color_rgb (Begins at: 49 Ends at: 60)
Complexity: | 2 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 12 | | OK |
metrics are OK
color_name_is_ok (Begins at: 63 Ends at: 72)
CalledNBR: | 3 | | OK |
LOC: | 10 | | OK |
metrics are OK
get_color_name (Begins at: 74 Ends at: 78)
LOC: | 5 | | OK |
metrics are OK
set_rgb_color (Begins at: 80 Ends at: 91)
CalledNBR: | 2 | | OK |
LOC: | 12 | | OK |
metrics are OK
unset_color (Begins at: 94 Ends at: 96)
Complexity: | 1 | | OK |
LOC: | 3 | | OK |
metrics are OK
set_color (Begins at: 99 Ends at: 110)
LOC: | 12 | | OK |
metrics are OK
set_color_from_color (Begins at: 113 Ends at: 130)
ParamNBR: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 18 | | OK |
metrics are OK
set_ps_color (Begins at: 132 Ends at: 136)
LOC: | 5 | | OK |
metrics are OK
color_none (Begins at: 138 Ends at: 142)
LOC: | 5 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-07 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
