[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.param.scale/process.c
|no clones | 0 monsters | 1 warnings
cvs at proxy.soccerlab.polymtl.ca
Sat Jul 8 05:20:51 EDT 2006
Hello brad,
ANALYSIS
raster/r.param.scale/process.c functions
process (Begins at: 16 Ends at: 243)
Complexity: | 11 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 39 | * | |
LOC: | 228 | ** | Warning |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-08 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
