[GRASS-QA] GRASS QA: glynn | ./grass6/lib/ogsf/gsd_views.c |2
clones ( GS2.c gsd_views.c )| 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Sun Jul 9 05:06:05 EDT 2006
Hello glynn,
ANALYSIS
lib/ogsf/gsd_views.c functions
gsd_get_los (Begins at: 32 Ends at: 81)
Complexity: | 1 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 21 | | OK |
LOC: | 50 | | OK |
metrics are OK
gsd_set_view (Begins at: 86 Ends at: 122)
ParamNBR: | 2 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 37 | | OK |
metrics are OK
gsd_check_focus (Begins at: 125 Ends at: 141)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 17 | | OK |
metrics are OK
gsd_get_zup (Begins at: 144 Ends at: 170)
CalledNBR: | 5 | | OK |
LOC: | 27 | | OK |
metrics are OK
gsd_zup_twist (Begins at: 173 Ends at: 248)
Complexity: | 7 | | OK |
LOC: | 76 | | OK |
metrics are OK
gsd_do_scale (Begins at: 251 Ends at: 262)
LOC: | 12 | | OK |
metrics are OK
gsd_real2model (Begins at: 265 Ends at: 278)
CalledNBR: | 3 | | OK |
LOC: | 14 | | OK |
metrics are OK
gsd_model2real (Begins at: 281 Ends at: 294)
LOC: | 14 | | OK |
metrics are OK
gsd_model2surf (Begins at: 297 Ends at: 318)
CalledNBR: | 2 | | OK |
LOC: | 22 | | OK |
metrics are OK
gsd_surf2real (Begins at: 321 Ends at: 329)
CalledNBR: | 0 | | OK |
LOC: | 9 | | OK |
metrics are OK
gsd_real2surf (Begins at: 332 Ends at: 340)
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
gsd_model2real gsd_real2model
In lib/ogsf/gsd_views.c clones of gsd_model2real are:
lib/ogsf/gsd_views.c gsd_real2model
In lib/ogsf/gsd_views.c clones of gsd_real2model are:
lib/ogsf/gsd_views.c gsd_model2real
Threshold GRASS6 key metrics values at 2006-07-09 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
