[GRASS-QA] GRASS QA: glynn | ./grass6/vector/v.digit/main.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Sun Jul 9 18:50:18 EDT 2006
Hello glynn,
ANALYSIS
vector/v.digit/main.c functions
Tcl_AppInit (Begins at: 25 Ends at: 87)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      29 |       |      OK |
LOC:          |      63 |       |      OK |
metrics are OK
main (Begins at: 89 Ends at: 196)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      55 |     * |         |
LOC:          |     108 |       |      OK |
metrics are OK
end (Begins at: 199 Ends at: 216)
Complexity:   |       2 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-09 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
