[GRASS-QA] GRASS QA: cho | ./grass6/lib/driver/Set_window.c |no
clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed Jul 12 17:12:01 EDT 2006
Hello cho,
ANALYSIS
lib/driver/Set_window.c functions
COM_Set_window (Begins at: 6 Ends at: 12)
Complexity: | 1 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 7 | | OK |
metrics are OK
window_clip (Begins at: 14 Ends at: 17)
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
window_box_clip (Begins at: 19 Ends at: 41)
Complexity: | 5 | | OK |
LOC: | 23 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-12 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 40 | 180 | 253 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
