[GRASS-QA] GRASS QA: cho | ./grass6/raster/r.to.vect/main.c |no
clones | 1 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Thu Jul 13 04:05:44 EDT 2006
Hello cho,
ANALYSIS
raster/r.to.vect/main.c functions
main (Begins at: 19 Ends at: 253)
Complexity: | 28 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 98 | *** | MONSTER |
LOC: | 235 | ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 40 | 180 | 253 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
