[GRASS-QA] GRASS QA: cho | ./grass6/vector/v.out.dxf/write_dxf.c
|no clones | 0 monsters | 1 warnings
cvs at proxy.soccerlab.polymtl.ca
Thu Jul 13 15:09:52 EDT 2006
Hello cho,
ANALYSIS
vector/v.out.dxf/write_dxf.c functions
dxf_open (Begins at: 16 Ends at: 24)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 9 | | OK |
metrics are OK
dxf_header (Begins at: 26 Ends at: 31)
Complexity: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
dxf_tables (Begins at: 33 Ends at: 38)
LOC: | 6 | | OK |
metrics are OK
dxf_blocks (Begins at: 40 Ends at: 45)
LOC: | 6 | | OK |
metrics are OK
dxf_entities (Begins at: 47 Ends at: 52)
LOC: | 6 | | OK |
metrics are OK
dxf_endsec (Begins at: 54 Ends at: 59)
LOC: | 6 | | OK |
metrics are OK
dxf_eof (Begins at: 61 Ends at: 67)
CalledNBR: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
dxf_limits (Begins at: 71 Ends at: 77)
ParamNBR: | 4 | | OK |
LOC: | 7 | | OK |
metrics are OK
dxf_linetype_table (Begins at: 81 Ends at: 86)
LOC: | 6 | | OK |
metrics are OK
dxf_layer_table (Begins at: 88 Ends at: 93)
LOC: | 6 | | OK |
metrics are OK
dxf_endtable (Begins at: 95 Ends at: 100)
LOC: | 6 | | OK |
metrics are OK
dxf_solidline (Begins at: 102 Ends at: 109)
LOC: | 8 | | OK |
metrics are OK
dxf_layer0 (Begins at: 111 Ends at: 117)
LOC: | 7 | | OK |
metrics are OK
dxf_layer (Begins at: 119 Ends at: 131)
LOC: | 13 | | OK |
metrics are OK
dxf_point (Begins at: 135 Ends at: 142)
LOC: | 8 | | OK |
metrics are OK
dxf_polyline (Begins at: 144 Ends at: 152)
LOC: | 9 | | OK |
metrics are OK
dxf_vertex (Begins at: 154 Ends at: 161)
LOC: | 8 | | OK |
metrics are OK
dxf_text (Begins at: 163 Ends at: 172)
ParamNBR: | 7 | ** | Warning |
LOC: | 10 | | OK |
at least 1 values are close to an outlier please consider revising code
dxf_poly_end (Begins at: 174 Ends at: 179)
LOC: | 6 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 40 | 180 | 253 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
