[GRASS-QA] GRASS QA: cho | ./grass6/vector/v.out.dxf/write_dxf.c
|no clones | 0 monsters | 1 warnings
cvs at proxy.soccerlab.polymtl.ca
Thu Jul 13 16:34:10 EDT 2006
Hello cho,
ANALYSIS
vector/v.out.dxf/write_dxf.c functions
dxf_open (Begins at: 17 Ends at: 40)
Complexity: | 6 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 24 | | OK |
metrics are OK
dxf_header (Begins at: 42 Ends at: 47)
Complexity: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
dxf_tables (Begins at: 49 Ends at: 54)
LOC: | 6 | | OK |
metrics are OK
dxf_blocks (Begins at: 56 Ends at: 61)
LOC: | 6 | | OK |
metrics are OK
dxf_entities (Begins at: 63 Ends at: 68)
LOC: | 6 | | OK |
metrics are OK
dxf_endsec (Begins at: 70 Ends at: 75)
LOC: | 6 | | OK |
metrics are OK
dxf_eof (Begins at: 77 Ends at: 83)
CalledNBR: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
dxf_limits (Begins at: 87 Ends at: 93)
ParamNBR: | 4 | | OK |
LOC: | 7 | | OK |
metrics are OK
dxf_linetype_table (Begins at: 97 Ends at: 102)
LOC: | 6 | | OK |
metrics are OK
dxf_layer_table (Begins at: 104 Ends at: 109)
LOC: | 6 | | OK |
metrics are OK
dxf_endtable (Begins at: 111 Ends at: 116)
LOC: | 6 | | OK |
metrics are OK
dxf_solidline (Begins at: 118 Ends at: 125)
CalledNBR: | 3 | | OK |
LOC: | 8 | | OK |
metrics are OK
dxf_layer0 (Begins at: 127 Ends at: 133)
LOC: | 7 | | OK |
metrics are OK
dxf_layer (Begins at: 135 Ends at: 147)
Complexity: | 2 | | OK |
LOC: | 13 | | OK |
metrics are OK
dxf_point (Begins at: 151 Ends at: 158)
LOC: | 8 | | OK |
metrics are OK
dxf_polyline (Begins at: 160 Ends at: 168)
LOC: | 9 | | OK |
metrics are OK
dxf_vertex (Begins at: 170 Ends at: 177)
LOC: | 8 | | OK |
metrics are OK
dxf_text (Begins at: 179 Ends at: 188)
ParamNBR: | 7 | ** | Warning |
LOC: | 10 | | OK |
at least 1 values are close to an outlier please consider revising code
dxf_poly_end (Begins at: 190 Ends at: 195)
LOC: | 6 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 40 | 180 | 253 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
