[GRASS-QA] GRASS QA: markus |
./grass6/raster/r.support/front/check.c |no clones | 0
monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Fri Jul 14 12:52:43 EDT 2006
Hello markus,
ANALYSIS
raster/r.support/front/check.c functions
check_stats (Begins at: 12 Ends at: 85)
Complexity: | 11 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 24 | | OK |
LOC: | 74 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
