[GRASS-QA] GRASS QA: hamish | ./grass6/lib/gis/ll_scan.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Sat Jul 15 06:25:43 EDT 2006
Hello hamish,
ANALYSIS
lib/gis/ll_scan.c functions
G_lat_scan (Begins at: 43 Ends at: 46)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
G_lon_scan (Begins at: 48 Ends at: 51)
LOC:          |       4 |       |      OK |
metrics are OK
G_llres_scan (Begins at: 53 Ends at: 59)
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
scan_ll (Begins at: 62 Ends at: 149)
Complexity:   |      19 |     * |         |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      88 |       |      OK |
metrics are OK
check_minutes (Begins at: 151 Ends at: 164)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
check_seconds (Begins at: 166 Ends at: 183)
Complexity:   |       7 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-15 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
