[GRASS-QA] GRASS QA: glynn | ./grass6/general/g.transform/main.c
	|no clones | 0 monsters | 0 warnings
    cvs at proxy.soccerlab.polymtl.ca
    Mon Jul 17 17:49:07 EDT 2006
Hello glynn,
ANALYSIS
general/g.transform/main.c functions
update_max (Begins at: 56 Ends at: 63)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
update_stats (Begins at: 65 Ends at: 71)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       3 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
diagonal (Begins at: 73 Ends at: 77)
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
compute_transformation (Begins at: 79 Ends at: 163)
Complexity:   |      22 |     * |         |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      33 |     * |         |
LOC:          |      85 |       |      OK |
metrics are OK
do_max (Begins at: 165 Ends at: 168)
LOC:          |       4 |       |      OK |
metrics are OK
do_stats (Begins at: 170 Ends at: 177)
CalledNBR:    |       5 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
analyze (Begins at: 179 Ends at: 195)
Complexity:   |       6 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
parse_format (Begins at: 197 Ends at: 224)
Complexity:   |      10 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
main (Begins at: 226 Ends at: 283)
CalledNBR:    |      18 |       |      OK |
LOC:          |      58 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-17 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      80 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
