[GRASS-QA] GRASS QA: hamish | ./grass6/ps/ps.map/ps_vlegend.c |no
clones | 0 monsters | 2 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jul 18 07:23:00 EDT 2006
Hello hamish,
ANALYSIS
ps/ps.map/ps_vlegend.c functions
PS_vlegend (Begins at: 12 Ends at: 237)
Complexity: | 24 | * | |
ParamNBR: | 1 | | OK |
CalledNBR: | 56 | ** | Warning |
LOC: | 226 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-18 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
