[GRASS-QA] GRASS QA: hamish | ./grass6/ps/ps.map/ps_vlegend.c |no clones | 0 monsters | 2 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jul 18 08:11:47 EDT 2006
Hello hamish,
ANALYSIS
ps/ps.map/ps_vlegend.c functions
PS_vlegend (Begins at: 12 Ends at: 237)
Complexity:   |      24 |     * |         |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      56 |    ** | Warning |
LOC:          |     226 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-18 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      80 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
