[GRASS-QA] GRASS QA: cho | ./grass6/raster/r.topmodel/topmodel.c |1 clones ( topmodel.c )| 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jul 18 15:51:59 EDT 2006
Hello cho,
ANALYSIS
raster/r.topmodel/topmodel.c functions
get_lambda (Begins at: 6 Ends at: 19)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
initialize (Begins at: 23 Ends at: 108)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      86 |       |      OK |
metrics are OK
implement (Begins at: 112 Ends at: 259)
Complexity:   |      16 |     * |         |
CalledNBR:    |      18 |       |      OK |
LOC:          |     148 |     * |         |
metrics are OK
get_Em (Begins at: 264 Ends at: 292)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
others (Begins at: 296 Ends at: 323)
CalledNBR:    |       1 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
topmodel (Begins at: 327 Ends at: 335)
CalledNBR:    |       3 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  get_lambda
In raster/r.topmodel/topmodel.c clones of  get_lambda are:
	raster/r.neighbors/bufs.c  rotate_bufs
Threshold GRASS6 key metrics values at 2006-07-18 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      80 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
