[GRASS-QA] GRASS QA: cho | ./grass6/raster/r.topmodel/main.c |no clones | 0 monsters | 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jul 18 15:51:59 EDT 2006
Hello cho,
ANALYSIS
raster/r.topmodel/main.c functions
main (Begins at: 25 Ends at: 234)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      50 |     * |         |
LOC:          |     210 |    ** | Warning |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-18 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      80 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
