[GRASS-QA] GRASS QA: paul | ./grass6/display/d.grid/plot.c |no
clones | 0 monsters | 2 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed Jul 19 05:06:07 EDT 2006
Hello paul,
ANALYSIS
display/d.grid/plot.c functions
plot_grid (Begins at: 13 Ends at: 103)
Complexity: | 7 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 36 | * | |
LOC: | 91 | | OK |
metrics are OK
plot_geogrid (Begins at: 106 Ends at: 228)
Complexity: | 11 | | OK |
CalledNBR: | 49 | * | |
LOC: | 123 | * | |
metrics are OK
init_proj (Begins at: 234 Ends at: 256)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 23 | | OK |
metrics are OK
get_ll_bounds (Begins at: 262 Ends at: 357)
Complexity: | 13 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 12 | | OK |
LOC: | 96 | | OK |
at least 1 values are close to an outlier please consider revising code
check_coords (Begins at: 364 Ends at: 429)
ParamNBR: | 8 | ** | Warning |
CalledNBR: | 15 | | OK |
LOC: | 66 | | OK |
get_heading (Begins at: 436 Ends at: 467)
Complexity: | 9 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 32 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
