[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/set_window.c |no
clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Sat Jul 22 21:43:54 EDT 2006
Hello glynn,
ANALYSIS
lib/gis/set_window.c functions
G_get_set_window (Begins at: 21 Ends at: 27)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
G_set_window (Begins at: 29 Ends at: 137)
Complexity: | 8 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 109 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-22 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 40 | 180 | 253 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
