[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.rast.edit/mk_new_layer.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Sun Jul 23 10:32:28 EDT 2006
Hello hamish,
ANALYSIS
display/d.rast.edit/mk_new_layer.c functions
make_new_cell_layer (Begins at: 15 Ends at: 92)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      36 |     * |         |
LOC:          |      78 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    39 |       179 |     249 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
