[GRASS-QA] GRASS QA: brad | ./grass6/vector/v.in.dxf/make_arc.c |no clones | 0 monsters | 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Thu Jul 27 04:45:59 EDT 2006
Hello brad,
ANALYSIS
vector/v.in.dxf/make_arc.c functions
make_arc (Begins at: 7 Ends at: 75)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      16 |       |      OK |
LOC:          |      69 |       |      OK |
at least 1 values are close to an outlier please consider revising code
make_arc_from_polyline (Begins at: 77 Ends at: 173)
Complexity:   |      13 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |      97 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-27 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    39 |       179 |     249 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
