[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/rem_pad.c |6
clones ( rem_get.c rem_io.c rem_pad.c )| 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Thu Jul 27 11:28:20 EDT 2006
Hello glynn,
ANALYSIS
lib/raster/rem_pad.c functions
Clone analysis:
This file has 6 potentially cloned functions:
REM_pad_delete REM_pad_list_items REM_pad_append_item _get_list REM_pad_get_item REM_pad_list
In lib/raster/rem_pad.c clones of REM_pad_get_item are:
lib/raster/pad.c R_pad_get_item
In lib/raster/rem_pad.c clones of REM_pad_delete are:
lib/raster/pad.c R_pad_delete
In lib/raster/rem_pad.c clones of _get_list are:
lib/raster/pad.c _get_list
In lib/raster/rem_pad.c clones of REM_pad_list are:
lib/raster/pad.c R_pad_list
In lib/raster/rem_pad.c clones of REM_pad_list_items are:
lib/raster/pad.c R_pad_list_items
In lib/raster/rem_pad.c clones of REM_pad_append_item are:
lib/raster/pad.c R_pad_append_item
Threshold GRASS6 key metrics values at 2006-07-27 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 39 | 179 | 249 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
