[GRASS-QA] GRASS QA: glynn |
./grass6/lib/fonts/for_grass/splitfont.c |no clones | 0
monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Thu Jul 27 21:14:31 EDT 2006
Hello glynn,
ANALYSIS
lib/fonts/for_grass/splitfont.c functions
main (Begins at: 8 Ends at: 121)
Complexity: | 9 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 33 | * | |
LOC: | 114 | * | |
metrics are OK
savechar (Begins at: 123 Ends at: 137)
Complexity: | 1 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 15 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-07-27 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 39 | 179 | 249 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
