[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:45 EDT 2006
Hello brad,
ANALYSIS
lib/gis/format.c functions
G__check_format (Begins at: 66 Ends at: 98)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
G__read_row_ptrs (Begins at: 100 Ends at: 165)
Complexity:   |       7 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      66 |       |      OK |
metrics are OK
G__write_row_ptrs (Begins at: 167 Ends at: 199)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
