[GRASS-QA] SOCCER LAB GRASS QA: no clones 1 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:49 EDT 2006
Hello cho,
ANALYSIS
vector/v.in.dxf/add_polyline.c functions
add_polyline (Begins at: 7 Ends at: 249)
Complexity:   |      43 |   *** | MONSTER |
CalledNBR:    |      40 |     * |         |
LOC:          |     243 |    ** | Warning |
1 metric are OUT OF RANGE!
write_pnts (Begins at: 251 Ends at: 284)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       4 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
