[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:51 EDT 2006
Hello cho,
ANALYSIS
vector/v.in.dxf/make_arc.c functions
make_arc (Begins at: 7 Ends at: 76)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      16 |       |      OK |
LOC:          |      70 |       |      OK |
at least 1 values are close to an outlier please consider revising code
make_arc_from_polyline (Begins at: 78 Ends at: 174)
Complexity:   |      13 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |      97 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
