[GRASS-QA] SOCCER LAB GRASS QA: 8 clones ( Dscreen.c list.c get_row.c get_row.c put_row.c put_row.c vect.c areas.c draw.c position.c get_row.c pad.c ) 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:52 EDT 2006
Hello glynn,
ANALYSIS
display/drivers/lib/pad.c functions
free_item (Begins at: 11 Ends at: 27)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
new_item (Begins at: 29 Ends at: 51)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
remove_value (Begins at: 53 Ends at: 72)
LOC:          |      20 |       |      OK |
metrics are OK
append_item (Begins at: 74 Ends at: 116)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
delete_item (Begins at: 118 Ends at: 138)
CalledNBR:    |       2 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
find_item (Begins at: 140 Ends at: 149)
CalledNBR:    |       1 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
pad_list (Begins at: 151 Ends at: 154)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
delink_pad (Begins at: 156 Ends at: 170)
LOC:          |      15 |       |      OK |
metrics are OK
create_pad (Begins at: 172 Ends at: 192)
LOC:          |      21 |       |      OK |
metrics are OK
delete_pad (Begins at: 194 Ends at: 212)
Complexity:   |       2 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
find_pad (Begins at: 214 Ends at: 222)
LOC:          |       9 |       |      OK |
metrics are OK
invent_pad (Begins at: 224 Ends at: 233)
LOC:          |      10 |       |      OK |
metrics are OK
Clone analysis:
This file has 8 potentially cloned functions:
  remove_value  new_item  append_item  create_pad  delete_item  find_item  delink_pad  delete_pad
In display/drivers/lib/pad.c clones of  delink_pad are:
	lib/driver/pad.c  delink_pad
In display/drivers/lib/pad.c clones of  append_item are:
	lib/driver/pad.c  append_item
In display/drivers/lib/pad.c clones of  new_item are:
	lib/driver/pad.c  new_item
In display/drivers/lib/pad.c clones of  create_pad are:
	lib/driver/pad.c  create_pad
In display/drivers/lib/pad.c clones of  find_item are:
	lib/driver/pad.c  find_item
In display/drivers/lib/pad.c clones of  delete_pad are:
	lib/driver/pad.c  delete_pad
In display/drivers/lib/pad.c clones of  remove_value are:
	lib/driver/pad.c  remove_value
In display/drivers/lib/pad.c clones of  delete_item are:
	lib/driver/pad.c  delete_item
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
