[GRASS-QA] SOCCER LAB GRASS QA: 1 clones ( Dscreen.c list.c
get_row.c get_row.c put_row.c put_row.c vect.c areas.c draw.c
position.c get_row.c pad.c main.c main.c command.c parser.c
GS2.c gethead.c anim_support.c draw.c position.c
site_attr_commands.c site_highlight_commands.c
togl_flythrough.c parser.c ) 1 monsters and 7 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:54 EDT 2006
Hello hamish,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 200 Ends at: 216)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 17 | | OK |
metrics are OK
G_define_flag (Begins at: 219 Ends at: 267)
Complexity: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 49 | | OK |
metrics are OK
G_define_option (Begins at: 270 Ends at: 323)
LOC: | 54 | | OK |
metrics are OK
G_define_standard_option (Begins at: 326 Ends at: 448)
Complexity: | 16 | * | |
CalledNBR: | 16 | | OK |
LOC: | 123 | * | |
metrics are OK
G_define_module (Begins at: 451 Ends at: 485)
CalledNBR: | 1 | | OK |
LOC: | 35 | | OK |
metrics are OK
G_parser (Begins at: 487 Ends at: 722)
Complexity: | 34 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 56 | ** | Warning |
LOC: | 236 | ** | Warning |
at least 3 values are close to an outlier please consider revising code
uses_new_gisprompt (Begins at: 725 Ends at: 770)
Complexity: | 5 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 46 | | OK |
metrics are OK
G_usage (Begins at: 772 Ends at: 933)
Complexity: | 31 | ** | Warning |
CalledNBR: | 42 | * | |
LOC: | 162 | * | |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 935 Ends at: 951)
Complexity: | 6 | | OK |
LOC: | 17 | | OK |
metrics are OK
G_usage_xml (Begins at: 953 Ends at: 1151)
Complexity: | 25 | * | |
CalledNBR: | 62 | ** | Warning |
LOC: | 199 | ** | Warning |
G_usage_html (Begins at: 1153 Ends at: 1369)
Complexity: | 40 | *** | MONSTER |
CalledNBR: | 71 | ** | Warning |
LOC: | 217 | ** | Warning |
1 metric are OUT OF RANGE!
generate_tcl (Begins at: 1371 Ends at: 1442)
Complexity: | 9 | | OK |
CalledNBR: | 24 | | OK |
LOC: | 72 | | OK |
metrics are OK
G_gui (Begins at: 1445 Ends at: 1467)
CalledNBR: | 8 | | OK |
LOC: | 23 | | OK |
metrics are OK
G_tcltk (Begins at: 1470 Ends at: 1485)
LOC: | 16 | | OK |
metrics are OK
show_options (Begins at: 1487 Ends at: 1516)
Complexity: | 4 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 30 | | OK |
metrics are OK
show (Begins at: 1518 Ends at: 1531)
CalledNBR: | 3 | | OK |
LOC: | 14 | | OK |
metrics are OK
set_flag (Begins at: 1533 Ends at: 1560)
LOC: | 28 | | OK |
metrics are OK
contains (Begins at: 1565 Ends at: 1574)
LOC: | 10 | | OK |
metrics are OK
set_option (Begins at: 1576 Ends at: 1636)
CalledNBR: | 13 | | OK |
LOC: | 61 | | OK |
metrics are OK
check_opts (Begins at: 1638 Ends at: 1675)
LOC: | 38 | | OK |
metrics are OK
check_an_opt (Begins at: 1677 Ends at: 1719)
Complexity: | 10 | | OK |
ParamNBR: | 4 | | OK |
LOC: | 43 | | OK |
metrics are OK
check_int (Begins at: 1721 Ends at: 1787)
Complexity: | 13 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 67 | | OK |
metrics are OK
check_double (Begins at: 1789 Ends at: 1829)
LOC: | 41 | | OK |
metrics are OK
check_string (Begins at: 1831 Ends at: 1858)
Complexity: | 8 | | OK |
LOC: | 28 | | OK |
metrics are OK
check_required (Begins at: 1860 Ends at: 1883)
LOC: | 24 | | OK |
metrics are OK
split_opts (Begins at: 1885 Ends at: 1948)
LOC: | 64 | | OK |
metrics are OK
check_multiple_opts (Begins at: 1950 Ends at: 1988)
CalledNBR: | 5 | | OK |
LOC: | 39 | | OK |
metrics are OK
check_overwrite (Begins at: 1991 Ends at: 2047)
Complexity: | 11 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 57 | | OK |
metrics are OK
interactive (Begins at: 2049 Ends at: 2077)
LOC: | 29 | | OK |
metrics are OK
interactive_flag (Begins at: 2079 Ends at: 2087)
LOC: | 9 | | OK |
metrics are OK
interactive_option (Begins at: 2089 Ends at: 2179)
Complexity: | 23 | * | |
CalledNBR: | 41 | * | |
LOC: | 91 | | OK |
metrics are OK
split_gisprompt (Begins at: 2181 Ends at: 2211)
LOC: | 31 | | OK |
metrics are OK
gis_prompt (Begins at: 2213 Ends at: 2258)
CalledNBR: | 20 | | OK |
LOC: | 46 | | OK |
metrics are OK
G_recreate_command (Begins at: 2260 Ends at: 2362)
CalledNBR: | 25 | | OK |
LOC: | 103 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
interactive_flag
In lib/gis/parser.c clones of interactive_flag are:
lib/gis/rm_colr.c G_remove_colr
Threshold GRASS6 key metrics values at 2006-06-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
